D5转换器 Revit
    使用D5转换器-Revit时出现报错:Rendering is currently not supported in the running instance of Revit.One reason for that to happen is that rendering...?
    这个报错的原因看起来是Revit本身缺少文件(素材),需要重新下载安装一下Revit素材库(Autodesk material library),在Autodesk的官网中提供了下载地址和安装方法:https://knowledge.autodesk.com/support/revit/learn-explore/caas/sfdcarticles/sfdcarticles/Rendering-features-are-currently-disabled-You-must-install-the-Rendering-library-to-use-rendering-features.html
    此回答是否有所帮助? 是 否
    Send feedback
    抱歉,我们无能为助。帮助我们利用您的反馈改进此文章。
    文档查看数
